Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Multi-colored snow noise when rendering
5 REPLIES 5
706 Views, 5 Replies
I am getting this grainy snow effect while using the render sequence command. Things look fine in the render view, but the images being saved come out as pure noise. Adjusting the render settings has no effect. What could be the cause of this?
Tags (3)
Labels (3)
5 REPLIES 5
ben.fischler
What plugin are you using, MtoA with Maya? What version?
in reply to: ben.fischler
I am using Arnold in Maya 2017
lee_griggs
Whats in the scene? Do you have a simplified sample scene that demonstrates the problem?
Lee Griggs
Arnold rendering specialist
AUTODESK
Stephen.Blair
Click Arnold > About. What version of MtoA? If you're not using the latest 2.0.2.4, you should get it from solidangle.com
// Stephen Blair
// Arnold Renderer Support
can you post your system specs? OS, GPU type/driver, maya version?
