Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Mtoa diagnostics log not outputting filename of the rendered image file.
1 REPLY 1
291 Views, 1 Reply
I'm rendering a sequence on the render farm. I recently updated mtoa arnold to 3.0.1 and now the renderfarm can't preview the rendered images. I found out that the render log doesn't output the filename anymore.
// [mtoa.translator] exr: Parameter filename is hidden on Arnold node defaultArnoldDriver@driver_exr(driver_exr).
This is what I get in the logs. I get the filename if I set the verbosity level to debug but I can't just set that as default. Is there a way to get the filename visible with verbosity level "warning" or "info"?
Thanks.
Tags (3)
Labels (3)
1 REPLY 1
Stephen.Blair
The filename is output after the render finishes.
From a log with Info level verbosity:
00:00:01 1986MB | [driver_exr] writing file `D:/Projects/maya/Support/images/tmp/torus_test_1.exr'
[mtoa.translator] is from MtoA during scene translation, while [driver_exr] is from the actual Arnold node that writes the output file.
// Stephen Blair
// Arnold Renderer Support
