Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
MtoA 3.1.0 issues
2 REPLIES 2
Slava_91
1972 Views, 2 Replies
MtoA 3.1.0 issues
Hi!
I have a little issues in mtoa 3.1.0 for maya 2017 up5
Time to time geometry with catmull-clark subdivision not full caching in render, some piece not rendered in firs start render after manipulating with geo(translate, scale or camera movement)
Denoise Beauty AOV not working
RGBA AOV not visible in ARW
Broken сamera movement in ARW (video file)
https://dl.dropboxusercontent.com/s/qfb4xzwftqxoc2a/2018-08-18_16-36-01.mp4
Standing warnings and error SynColor with ACES colorspace.
# Warning: options: parameter "default_gpu_names" is deprecated, use "gpu_default_names" #
# Warning: options: parameter "default_gpu_min_memory_MB" is deprecated, use "gpu_default_min_memory_MB" #
# Warning: [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "defaultArnoldDriver@driver_exr_denoise", "defaultArnoldDriver@driver_exr.RGBA" #
# Warning: options: parameter "default_gpu_names" is deprecated, use "gpu_default_names" # "
# Error: [SynColor 2018.0.80]: view_transform menu selection is not available: <null>
Does anyone have this problem to?
Labels (5)
2 REPLIES 2
Slava_91
in reply to: Slava_91
However optix not working with any AOV for me
Slava_91
Optix denoiser works fine, I found problem.
I replace older mtoa version to new, and have two version of optix dll in bin folder.
