Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
MixShader transition slowness
2 REPLIES 2
darioOrtisi
294 Views, 2 Replies
Hello. I'm using the mixshader to make a transition of two different shader. One solid shader and the second with opacity, like falloff xRay. I do an animation keyframe for transitioning the two. When the mix value start tthe animation, the render time began slow ever. The two shaders as single without transition have a good rendertime. Obviously there is opacity falloff, but the are ok.
SO there is a metod(ok i can render the two sequence and composite them) faster then using mixShader? The layer can be more fast?
Is ti normal?
Dario
Labels (3)
2 REPLIES 2
in reply to: darioOrtisi
Yes, There are two ways to achieve desire effect.
First, you can try rendering individual shader and merge them in compositing (post effect)/
Second, create two render layer. then override and assign aiMatte shader (shader1 or 2 box). Now render Both and use in compositing.
darioOrtisi
Thanks. I did it in comp(post effects)
Technology Administrators
