Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Maya2019 crashes when rendering FumeFX with Arnold.
5 REPLIES 5
701 Views, 5 Replies
Maya2019 crashes with a Fatal Error when I check the FumeFX results in Arnold Render View.
Arnold is MtoA 3.2.2 Arnold 5.3.1.1
Renders fine in Maya2018.
I don't understand what the problem is at all.
You will also see the following warnings each time.
# Warning: parameter "step_size" is declared already #
# Warning: node "FumeFXStandardVolume" is already installed #
# Warning: node "FumeFXArnoldVolume" is already installed #
# Warning: node "FumeFXShader" is already installed #
As for Warning, though, it may be negligible.
The biggest problem is that even if you can ignore the warning, you can't render it.
I'm having trouble getting the job done using FumeFX.
Is there a solution to this?
Thank you in advance for taking a look at this.
Tags (3)
Labels (3)
5 REPLIES 5
lee_griggs
Are there any other errors in the log file?
Lee Griggs
Arnold rendering specialist
AUTODESK
@Lee Griggs
Thank you for your reply.
I don't know the contents of the log file myself, but
At least I don't see any Error characters.
I want to attach a text file of the Maya crash log report, but the upload is disabled.
lee_griggs
Just paste the text here.
Lee Griggs
AUTODESK
I'm translating the language, so I'm sorry if it sounds strange.
in reply to: lee_griggs
hear the crash log.MayaCrashLog200519.1141.log.txt
