Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Maya 2020 crashes on IPR render
3 REPLIES 3
1241 Views, 3 Replies
Maya crashes when selected IPR render. This is only happening when I have two panels in the viewport i.e, Perspective view on the left and Render view on the right. I have updated all the GPU related drivers. Re-installed the software couple of times. Yet, this issue isn't solving.
There is an error displayed like this,
701MB WARNING | [mtoa] [<built-in>] [node aov_write_vector] Assigning temporary node id 1138176 to associated Maya type name aiAovWriteVector.
[aov] no valid output statements found: could be a progressive render without a display window
Software details -
Maya 2020
Arnold 6
MtoA version : 4.0.0
Hardware details -
CPU : Intel core i9-9900k
GPU : Nvidia GeForce RTX 2070
Tags (1)
Labels (1)
3 REPLIES 3
Stephen.Blair
I don't get a crash.
The warning and the other message imply this is a specific scene that crashes.
Can you post a full Arnold log?
// Stephen Blair
// Arnold Renderer Support
I had a similar problem and fixed it by doing the following:
- make sure the file you are rendering from is located in the local drive and you are also rendering out in a local drive (I was rendering from an old external hard drive - so i copy the whole folder in the local drive)
- In Render settings > System tab make sure you have selected Render device: GPU and select your Nvidia Geforce RTX 2070 from the Manual Device selection (Local render)
(in my case I also applied Render Device Fallback: CPU )
That worked out for me so far - let me know if that works for you
iamhacklife
Maya crashed, when I stoped IPR render!
Technology Administrators
