Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Isolate selected missing in MtoA 4.2.3 renderview
6 REPLIES 6
Leo472714
360 Views, 6 Replies
Hello I am currently missing the Isolate select button in the Arnold render view looks like a white dot with a dashed line around it. It was used to view selected shader nodes in the render view. I'm not sure if this was removed recently in a update, If I need to turn on some setting or if its a genuine bug/error
Using arnold 6.2.1.1 on maya2020
Tags (1)
Labels (1)
6 REPLIES 6
lee_griggs
in reply to: Leo472714
Check it is enabled here:
Lee Griggs
Arnold rendering specialist
AUTODESK
Leo472714
I have to be overlooking something? mine does not even have a windows menu?
lee_griggs
I would re-install the plugin. If that doesn't work try new Maya Prefs maybe?
https://www.arnoldrenderer.com/arnold/download/
Lee Griggs
AUTODESK
That's the Maya Render view not the Arnold one from the Arnold > Render menu
Ashley Handscomb Retallack
Senior Software Engineer (Arnold)
Arnold Documentation | Arnold Downloads
lee_griggs
https://docs.arnoldrenderer.com/display/A5AFMUG/Arnold+RenderView+Window
Lee Griggs
AUTODESK
Thank you! I knew it had to be something simple.
Technology Administrators
