Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to turn of GI?
2 REPLIES 2
7319 Views, 2 Replies
How to turn of GI?
I noticed in the Lights topic of the User Guide, in the 'Samples' section it states this:
"If the issue is noise in a specular highlight, you will need to confirm that the source is the direct light and not a secondary ray type (such as glossy). This is easy to achieve by turning off global illumination; set the GI_diffuse_depth, GI_glossy_depth and GI_reflection_depth to zero (this essentially turns off all global illumination). "
https://docs.arnoldrenderer.com/display/AFMUG/Lights
After searching around I can't find anywhere else mentioning how to turn off GI in Arnold. Where do I set 'GI_diffuse_depth' etc?
Tags (2)
Labels (2)
2 REPLIES 2
lee_griggs
It means Ray Depth . Setting Diffuse samples to 0 also works.
Lee Griggs
Arnold rendering specialist
AUTODESK
Okay, I got it, so it would be setting these parameters to 0:
Technology Administrators
