Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to remove effect from opacity material on SSS material?
1 REPLY 1
kinglive.pop
191 Views, 1 Reply
Hi, I need render hair cards with SSS material together,but when I using opacity material,the SSS material appear some of dark line.
I already check, it is Diffuse Reflection ,I try to remove it with AiraySwitch but not working.
How to disable Diffuse Reflection from objects with opacity material? or how to fix it?
Thank you.
Tags (1)
Labels (1)
1 REPLY 1
lee_griggs
in reply to: kinglive.pop
In the object shape visibility settings?
https://docs.arnoldrenderer.com/display/A5AFMUG/Visibility
If that doesn't work can you share some images and/or a simple scene.
Lee Griggs
Arnold rendering specialist
AUTODESK
