Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to get Arnold to cast shadows on tranmissive glass objects ?
8 REPLIES 8
Message 1 of 9
remi
2741 Views, 8 Replies
Hello everyone,I'm running into a big problem on a project where i need to render glass objects with moving shadows.The problem being : i can't seem to get any shadows from a glass material !
Tried :
  • Opaque ON/OFF (does nothing)
  • Lowering transmission a bit (start to create shadows but not strongly enough and we loose quickly the glass so not an option at all)
  • trying all light types
  • C4DtoA and also MtoA : same result
I've come across a few tutorials where there is indeed shadows being casted (eg :https://www.youtube.com/watch?v=QYmq_cSb5Mg ) But opening this scene or trying to replicate it doesn't produce anything.
Can somebody point me in the right direction or should i simply switch render engine for this job ?
best
Labels (3)
8 REPLIES 8
Message 2 of 9
lee_griggs
in reply to: remi
No need to change render engines. Just reduce the Transmission Weight so that it is not fully 1.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 9
remi
in reply to: remi
Hi Lee,
Thanks for the reply but that was my second point in the list : the shadow produced when reducing the transmission to 0.9ish is not realistic, it's just a "faded" shadow. So not a good work around for me sadly 😞
Message 4 of 9
lee_griggs
in reply to: remi
Can you upload the scene somewhere?
Lee Griggs
AUTODESK
Message 5 of 9
Stephen.Blair
in reply to: remi
Another way is to use a rayswitch (to get around "smart opaque") and use opacity / caustics for the shadow
// Stephen Blair
// Arnold Renderer Support
Message 6 of 9
s.thifault
in reply to: remi
You can leave the transmission to 1 and use transmission depth instead and some scatter, it will give you more realistic shadows.
Message 7 of 9
rico
in reply to: remi
In older versions of Arnold ther was a shadow. Now the opake switch is set automatically if you have a transparent object. I think it would be helpful to have the option to acticate the old behavior.
Message 8 of 9
lee_griggs
in reply to: remi
Did you try any of the above suggestions? Can you upload a simples scene somewhere?
Lee Griggs
AUTODESK
Message 9 of 9
diego_marcelino97VGE
in reply to: remi
It was quite difficult to find a solution for this, I looked for several tutorials and found nothing. However, testing Arnold's settings I found a very simple solution! Just open "Render Settings" (in C4D); then go to “Arnold” and open the “Ray Depth” option; find the "Transparency Depth" option and reduce it to 1 or any other value that leaves the shadow visible in your scene. I hope this helps!
Simplified process:
C4D > RENDER SETTINGS > ARNOLD > RAY DEPTH > TRANSPARENCY DEPTH > VALUE IN 1 OR ANY OTHER VALUE THAT MAKES THE SHADOW VISIBLE.
Technology Administrators
