Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to fix a blurry Arnold Render?
5 REPLIES 5
4627 Views, 5 Replies
So no matter what material I use, Arnold makes the texture blurry when I render it out. Maya software and Hardware do not produce the same results, they come out perfectly fine. Arnold is messing up for some reason. Is it because i'm using a small texture? The Blue Grey background pic is the maya viewport. The black background picture is the Arnold render.
Tags (1)
Labels (1)
5 REPLIES 5
Stephen.Blair
Post an example texture.
Otherwise, use the Image node and use a negative value for the mipmap bias. And/or change the filter to Closest if all your textures are pixelated like that.
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
Do you mean the Filter type circled in red? I did notice that my texture is appearing Blurred in the UV Editor. Is it someone possible to make it clear and sharp? Maybe thats the reason I suppose5123-test3.png
Update, just switched it to the Aisurface and it is now clear in the UV editor, however, arnold still renders it out blurry
T0M0X
Select your texture, go to Attribute Editor and in Arnold section change Filter Type to closest.
in reply to: T0M0X
Its fixed! Thank you!
Technology Administrators
