Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
​How correctly connect Metalness map? and what is a benefit in Hight map?
2 REPLIES 2
koostic.moloco
2032 Views, 2 Replies
How correctly connect Metaness map? and what is a benefit in Hight map? i connect it with displasement shader, but not is changed...
Labels (4)
2 REPLIES 2
lee_griggs
in reply to: koostic.moloco
Try connecting a Range shader in-between Metalness and the Metalness map.
Have you increased subdivision iterations for the mesh? Try it on a plane to see if it works first.
Lee Griggs
Arnold rendering specialist
AUTODESK
Thanks, i will. Yep, i have increase subdivision iterations, catlark, 3... Yes, see the result.
