Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How can I use my vertex color alpha data from a RGBA colorset to provide it as opacity in aiStandardSurface shader ?
4 REPLIES 4
646 Views, 4 Replies
Tags (1)
Labels (1)
4 REPLIES 4
Stephen.Blair
You can't do it with aiUserDataColor, because that shader is RGB, not RGBA.
I suppose you could un-hide aiUserDataRGBA (the user_data_rgba node from Arnold) and use that. To do that, edit mtoa.mtd
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
You Rock Man. Thank you so much. It works. For those who have same problem, you should edit mtoa.mtd and look for [node user_data_rgba] and make maya.hide BOOL "True" to "False". You can find "Out alpha" output by right click on "aiUserDataRgba" node and "Show all attributes".
I would be a better solution to give us the option to choose between RGB and RGBA mode inside the aiUserDataColor node.
hoanghon.trenrung
We can use alpha or rgb from vertex color in the new version of arnold
