Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Displacement problem
6 REPLIES 6
Slava_91
1084 Views, 6 Replies
I have a ainoise remapping for a shader mix mask, and i put this texture to displacement mix with other textures, but after displaced mesh, mask has an offset
Why this happen and how to fix?
displacement texture isolate http://take.ms/NCWvE
Tags (1)
Labels (1)
6 REPLIES 6
zenop
in reply to: Slava_91
I noticed the same issue.
Slava_91
in reply to: zenop
yep, this is not good...
if I correctly understood , it mix after displace, and not before displace
I think it is not correct
lee_griggs
Do you have a simplified scene and / or .ass file that you can share?
Lee Griggs
Arnold rendering specialist
AUTODESK
Slava_91
in reply to: lee_griggs
Mr.baiking
I've this issue when i have a texture connect to opacity and then mix another texture connect to displacement , seems there is kind of order (before or after)?
Mr.baiking
If there is a displacement blend/mix shader it would be great
