Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Car Paint anf Bump
8 REPLIES 8
Message 1 of 9
1044 Views, 8 Replies
Car Paint anf Bump
Hi!, I'm triying to render a carpaint shader with a bump, but I can´t connect it. It's a limitation? thx!
Tags (1)
Labels (1)
8 REPLIES 8
Message 2 of 9
lee_griggs
How are you connecting it? There is currently a bug with Coat Normal.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 9
Hi! I connect a normal map to "normal camera" in the shader, but don't have effect
Message 4 of 9
lee_griggs
Coat Normal? Right that's broken. It should be fixed in a future release.
Lee Griggs
AUTODESK
Message 5 of 9
Jordi_GarcÃ_a
I connect a normal map to “normal camera” in the shader but don’t have effect
Message 6 of 9
gryphiz
Same thing with MaxtoA.
Any news on when will the fixed version come?
Message 7 of 9
arkitek62
any news about it guys ?
Message 8 of 9
Jessica_V
Hi! I Use Arnol 5.1.0.1 and I have the same situation. I can plug the out Value of a aiBump2D in The normal Camera chanel of a aiCarPaint shader, but it did not affect my render. I try the same aiBump2D on aiStandarSurface and it work perfectly well. I wonder if it's a bug or if the bump need to be plug in a special way for the aiCarpaint Shader.
Message 9 of 9
Stephen.Blair
Fixed in Arnold 5.1.0.0
Use the Coat Normal.
// Stephen Blair
// Arnold Renderer Support
