Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
arnold noice un able to finish given frames
6 REPLIES 6
nothingdean
509 Views, 6 Replies
erthing else is working just fine but when i hit denoise ,it olny does 9 frames n stops.
i did erthing jst ryt but cant figure out the issue ,failed to get a solution else where.
i kindly request i get a reply soon,am working a project and the noice is really proving to be handy big time.
Tags (1)
Labels (1)
6 REPLIES 6
Stephen.Blair
in reply to: nothingdean
Well, what's logged in the script history?
// Stephen Blair
// Arnold Renderer Support
nothingdean
here is my log history
after 9 frames,it says unable to load file for the rest .
log.txt
Stephen.Blair
Do those files even exist? There's a mix of frames with different frame padding. For rexample:
  • st_Famillewhite lookpersp3.10.exr
  • st_Famillewhite lookpersp3.0010.exr
I would clean up that folder, so that you have frames with just one type of frame padding in the file name.
// Stephen Blair
ep
Hi there,
I´m having the exact same issue and it´s a Noice problem, not a frame padding one, since the frames are named correctly, all having the same padding. In my case, I have a 4 digit padding.
It just seems that Noice can´t go beyond frame 0009 since at that point it starts looking for frame 10 (instead of 0010).
Here´s a copy of my log showing where this happens:
noice 5.1.1.0 [e338d869] - the Arnold denoiser
Loading images...
Loading file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0008.exr".
Using feature AOV 'diffuse_albedo'
Using feature AOV 'N'
Using feature AOV 'Z'
Working with 1 frame.
Will denoise AOV "RGBA"
Start denoising (patch radius 3, search radius 6, variance 3)
Denoising RGBA
Finished denoising
Saving image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0008_denoised.exr (1280 x 720 x 4)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr
------------------------ (9/122)
Loading images...
Loading file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009.exr".
Denoising RGBA
Finished denoising
Saving image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_0009_denoised.exr (1280 x 720 x 4)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr
------------------------ (10/122)
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr
------------------------ (11/122)
Loading images...
Unable to load file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_10.exr".
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_12.exr
------------------------ (12/122)
Loading images...
Unable to load file "/Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_11.exr".
/Applications/solidangle/mtoa/2018/bin/noice -i /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13.exr -o /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13_denoised.exr -ef 0 -sr 6 -pr 3 -v 3.0
Denoising image /Volumes/ARCHIVO AD/RESPALDO DISCO TRABAJO/01_REPRETEL/ESPECIALES/ANIVERSARIOS/25 ANIVERSARIO/RENDERS/CIERRES/CICLO_RENDER_LAY/CICLO_RENDER_LAY_13.exr
------------------------ (13/122)
Stephen.Blair
@Esteban Pacheco
Please ask a new question. Don't post an answer.
https://answers.arnoldrenderer.com/questions/ask.html?space=12
// Stephen Blair
ep
Done. Thanks
Technology Administrators
