Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
SSS creating weird wireframe on skin render
3 REPLIES 3
ddfzhh
334 Views, 3 Replies
Hi guys.
I am encountering a weird problem which the SSS is leaving wireframe-like textures on my skin. I know for sure it is SSS because I isolated all the maps, and find out that as long as there is SSS on, there will always be this weird texture on my model. At first, I thought it was a problem with the type of SSS I am using, so I switched from random walk to diffusion but it still is not working. Included with this file is a photo of my node tree. Thanks !!
3 REPLIES 3
lee_griggs
in reply to: ddfzhh
Check the mesh. Are the normals correct? What happens when you soften the edges? Does it happen on a sphere with the same shader?
Does it happen with randomwalk/2 SSS too?
Lee Griggs
Arnold rendering specialist
AUTODESK
ddfzhh
in reply to: lee_griggs
Yes, the normals are correct. The edges are soft. And everything is normal when applying the shader to a sphere.
I did kinda find a solution tho. I applied catclark subdivision for the face mesh, and the lines go away. I don't know if that is the correct way to do it.
ddfzhh
in reply to: ddfzhh
And yes it did happen to random walk 2
Technology Administrators
