Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Operators - Turn on\off light for selection
3 REPLIES 3
CiroCardoso3v
364 Views, 3 Replies
Need some help with this one. I want to have one light affecting just a specific mesh and I can't do light lighting, because I am using Xrefs.
The Disable Operator node, disables something the light for everything in the scene, so I wonder if the Set Parameter node can be used for this. I am trying something like
/Arnoldlight001.on = off \ 0 \ false
Is this possible with Arnold Operators?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Tags (3)
Labels (3)
3 REPLIES 3
This is what I am trying to do
Ciro Cardoso
In that screenshot, you're selecting a polygon mesh and then trying to set a light parameter, so that won't work as expected.
You can use selection to select some lights, and then set light parameters.
For what you want to do, I think you would need to select the box, and then set the light linking parameters. That's the only way a light can apply to just some objects.
The XRefs will be translated to actual Arnold nodes, so we'd have to look at what is in a translated frame.
// Stephen Blair
// Arnold Renderer Support
Thanks for the reply. So could I set light linking parameters with Arnold Operators without having to assign an Arnold Properties modifier? This is a good example, why the light linking should be done per light and not per object.
Also, I am not sure if the Arnold Properties Modifier would work on a Forest Pack object.
Thanks for your reply.
Ciro Cardoso
