Make all the Advance Steel commands repeatable
Almost all the Advance Steel commands cannot simply be repeated by entering the Enter key or the space bar, since a sub-function is often connected to a primary command.
Advance Steel is AutoCAD based software, but cannot use his advantages. Please correct this illogical behavior.
Banal examples:
5 Comments
IR8ASU1
Yes please! I would particularly like to see the 'Insert Weld Point' command made repeatable.
stefan.dohr
Simply put an asterix in front of the command line.
Done... 😉
bigcarl5000kg
Hi @stefan.dohr ,
i know this ... and I will do the same with every new installation, and for any such command ... that is not the solution.
It must work the same way as with native ACAD commands, via Enter or Space ... and that's our goal 😉😁
IR8ASU1
@stefan.dohrThanks for the tip.
Banal examples:
• Dimensioned and labeled general arrangement and shop drawings are automatically created from
the model.
• The Advance Document Manager manages all general arrangement and shop drawings. The
update tool in the Document Manager makes single click drawing adjustments possible after
model changes.
• Structured BOMs (bills of materials) and NC-information are also created from the model and
include all model information such as part marks and quantities. The Document Manager also
controls these documents.
