Solid cutaway (solid cut with clipplanes)
It will be good to have a solid cut when using clipplanes.
or, like it is possible in keyshot, for example, use other geometry as a cut object in conjunction with a special cutaway material.
Working with mechanical stuff now I have to really cut the model with Inventor.
best
Chris
1 Comment
Correct me if I'm wrong, but as soon as VRED converts CAD data to surfaces and polygons, any information about "solids" is lost as far as I know.
I can't think of a way how VRED would evaluate the area between surfaces and come up with a solution for the question whether the area should be a solid (and thus appear with a planar surface when cut) or be like the air between components.
The normal vector (A-/B-Sides) might help to support certain algorithms, but false evaluation and undesired side-effects might be the norm.
