Scattering Tool
Scattering Tool
It would be great if VRED offered a feature that allows scattering objects (as instances) across a base surface using customizable parameters. A common use case would be distributing vegetation within environment scenes. A nice example of this can be seen in D5 (D5 Scatter Tool). The following capabilities would be especially helpful for configuring scattering.
Selection of the Scatter Objects
  • Choose a single object or a collection of objects (e.g. from an asset library)
Distribution Methods
  • Scatter across the entire selected geometry
  • Scatter within specific sub‑areas (of the geometry):
    • Place objects by clicking directly on the base surface
    • Brush‑based distribution with adjustable brush size
    • Distribution along splines
    • Use of color maps to define sub‑areas, enabling different objects or collections based on color regions
Distribution Details (depending on the placement method)
  • Density: Objects per unit area, optionally controlled by a density map
  • Weighting: Probability of occurrence for each object within a collection
  • Distance: Minimum/maximum spacing between objects, optionally using collision volumes
  • Region settings (region size, blur, etc.):
    • For the “entire geometry” method, regions can be generated randomly based on size and frequency (e.g., Region 1 with Object A, Region 2 with Object B)
    • Smooth transitions between regions adjustable via blur parameters
  • Alignment: Align objects to surface normals or keep alignment independent
  • Offset: Vertical offset of all scattered objects from the base surface
  • Collisions: Options for handling collisions with other scene objects
Variation
  • Random scale values (min/max) per axis or uniform scaling
  • Optional position jittering (min/max) per axis
  • Random rotation values (min/max) per axis
  • Seed value to control the overall randomness of the scattering variation
