Light target manipulators
It would be nice to have aim targets on lights. Similar to the aim on the "Camera and Aim". So you can have lights that are constrained to the target and be able to move the target and light manipulator independently while having the light always pointing to the target.
Richard
4 Comments
Maybe you can try to drag a light into an aimed camera to use the camera as a node.
richardlevene
Hi Adam,
Yeah that is definitely a hack you can do but it is not really that scene organisation friendly. Plus if you want to move the light you can't really select the light, you have to select the camera. But yes it is a workaround for now to get that aim functionality to a light. It would just be nice if the light had it natively.
Richard
lukas_faeth
Status changed to: Accepted
seiferp
Use the Constraint Editor to apply an Aim Constraint to any object. Create a new Aim Constraint, set an empty group or a specific object as the target, and drag all lights into the constraint node.
