Allow Bulk Variant Set editing
When making a change to a variant set - currently, you need to go through the Sets one by one to make a change.
Let's say you need to change a geometry switch, and that switch is present in a Variant Group, and the Group has 100 Variant Sets in it. Currently, you need to manually go into each Set and manually adjust the switch.
It would be great if you could bulk select the whole group, and make a change to a specific line item/switch and have it update to any selected Set.
Currently, this functionality works in Cameras where you bulk select a viewports in a camera and then make a change and it be applied to all selected cameras - it would be a huge time save if this was available for Variant Sets.
1 Comment
seiferp
This requested feature is available in VRED 2027.1.
