VRED Shadow Plane Deleted
For some reason, on raytracing, no ground shadow is generated. It appears I may have deleted the shadow plane on my environment as when I select it in the graph with wireframe activated, nothing appears in the window whereas when I select the dome, it is highlighted with a wireframe. This occurs with all the environments on the file, it also seems the shadow material in the materials lister is missing. Could anyone help?
Christian_Garimberti
it is strange that you have the Shadowplane node in the scenegraph but you see nothing if you select it. You wrote "on raytracing": do you mean that in OpenGL you see it?
If the problem is the material missing, you can recreate it from the material editor and then add it to your shadowplane.
If also the shadowplane is completely missing you can create a new plane from the scene, create, plane and add it to every environment you have in your scene.
Or add a new environment from the assets, and copy the shadowplane from it.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Thank you Chris, I shall have a go!
