VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
VRED MediaEditor / Version of WebEngine
6 REPLIES 6
marc.winter2
630 Views, 6 Replies
1. Is it correct, that the WebEngine runs with “Mozilla/5.0, Chrome/56.0.2924.122, …” from 2016?
2. If yes, is it possible to replace it manually with a newer version?
3. If not, which Chrome Version runs in the latest build of VRED?
Thanks in advance!
6 REPLIES 6
seiferp
in reply to: marc.winter2
We are using the qtwebengine that comes with Qt. VRED is currently using Qt 5.12.6 wich is using Chromium 69. Keep this in mind when using features/css styling etc. that were introduced with a newer Chrom version and look different in your browser compare to what you see in VRED.
marc.winter2
in reply to: seiferp
Vred2019.2 UserAgent:
Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) QtWebEngine/5.9.5 Chrome/56.0.2924.122 Safari/537.36
Vred2020.3 UserAgent:
Mozilla/5.0 (Windows NT 6.2; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) QtWebEngine/5.12.3 Chrome/69.0.3497.128 Safari/537.36
I know, this is very specific, but ...
The QT Webengine supports access to its internal Chromium Flags (@see https://doc.qt.io/qt-5/qtwebengine-debugging.html, https://myprogrammingnotes.com/pass-parameters-ch...).
Is it possible to achieve this in VRED too? Do we have access to the instance of the Webengine via script?
marc.winter2
by a quick search i've found the modules vrWebEngineObj and vrWebOverlay
vrWebEngineObj sounds promising but there is not much. No class only these methods.
  • bool hasWebEngineFocus()  Return true if a web engine has the focus.
  • bool isWebEngineInteractionEnabled()  Return true if interaction with web engines is enabled.
  • sendToWebEngine(name, event, data) Sends a custom event to a web engine.
  • setWebEngineInteractionEnabled(enabled) Enables or disables the interaction with all web engines in the scene.
vrWebOverlay has a class, a constructor and inherits from some baseclasses. But nothing in you are looking for.
  • __init__(url) The constructor of the vrWebOverlay class.
  • hide() Hides the frame.
  • setFrame(x) Sets the frame.
  • setOpacity(opacity) Sets the opacity of the overlay.
  • setUrl(url) Sets the url.
  • show() Shows the frame.
  • toggleShow()
Best reagards
markus_keller
Unfortunately we currenly do not yet have a generic scripting interface for WebEngines.
The environment variables from https://doc.qt.io/qt-5/qtwebengine-debugging.html should work. We're not doing anything to prevent that. I just tested with QTWEBENGINE_REMOTE_DEBUGGING and was able to debug the website displayed in a frontplate by connecting from Chrome to the specified port.
Markus Keller
Sr. Software Engineer
Hi Markus,
Thank you. This sounds promising. We'll take a look.
Best regards
