Hello
I'm wanting to trigger a material switch using the HTC Vive motion controllers.
Currently, I have a basic sphere set up which shares a touch sensor and switch material cycle with the vehicle I'm working on. I can manually change them upon a mouse click in real time, which is good - but how would I implement say, a button press, or collision event so when the motion controller is in the sphere, it can cycle through the materials?
I have no knowledge of Python, and am willing to learn - if there's anywhere anyone can point me to get to grips with it, that'd be awesome!
You just need to create a Touch Sensor on your node ( Interaction > Touch Sensor), with a variant set wich will change your material, then when you'll click with your controller on the node, your material will change. (for example)
Hello
Thanks for your reply!
I have that set up with the relevant code, and I can change material with a trigger press, for example:
def trigger1Pressed():
controller1.setPickingAxis(1)
controller1.showPickingAxis(true)
print "Trigger 1 Pressed"
def trigger1Released():
pickedNode = controller1.pickNode()
selectNode(pickedNode)
triggerTouchSensor("r8_gt_mb:r8_gt_obj:r8_gt_body_TouchSensor")
controller1.showPickingAxis(false)
print "Trigger 1 Released"
However, the material changes no matter where I'm aiming, is there a way to stop this happening? And Only have it change when you're aiming at the object?
Sorry if this is all very simple, I am very new to both Python and VRED!
Thanks again
You should try this :
- Put this function in your script
def triggerSensor( node): if node.hasAttachment("TouchSensorAttachment"): touchAttachment = node.getAttachment("TouchSensorAttachment") acc = vrFieldAccess(touchAttachment) if acc.isValid(): variantSetName = acc.getMString("variantSets") for vset in variantSetName: selectVariantSet(vset) controller1.triggerHapticPulse(0,1000) return parentNode = node.getParent() if parentNode.isValid(): triggerSensor( parentNode)
- Then, just keep that in your Triggers functions :
def trigger1Pressed(): controller1.setPickingAxis(0) controller1.showPickingAxis(true) def trigger1Released(): pickedNode = controller1.pickNode() controller1.showPickingAxis(false) triggerSensor(pickedNode)
With that, if you have a touchsensor attached to a node, when you'll aim it and click it, it should work...
Hello!
Thanks for your reply!!
That has solved my issue, really appreciate the help!!
All the best
Harry
