Does anyone know if Vred Design has a maximum render size limitation? I may need to render out 5k or so frames and the price difference between Design and pro is pretty significant.
Solved by marcus_fritzen. Go to Solution.
No, there is no image export render size limitation in VRED Design.
Marcus
Only in Vred the Image Render Resolution is limited to 8MPixel and the Movie and Display Render Resolution is limited to HD.
