Vred Controller multiple times in Scene
HI
since 2018.1 and 2018.2 i guess my controllers are showing up multiple times in the Szene floating. Only one pair of them is tracked the other once are just hanging in the szene if you try to select them they disappear out of your vision and appear close to your head.
Any ideas how to get rid of this problem?
Fast help would be needed i have a presentation tomorrow.
Cheers
Klaus
(Will test it in 2018 as soon as possible)
michael_nikelsky
This happens when you save the scene while the Vive is running. In that case the geometry of the controller is part of the scene and is saved with the file just like any other geometry. The next time you load the scene the geometry will be just like any other geometry and new controllers will be created.
This is a known issue, we are trying to find a solution on how to prevent the nodes from getting written to the file. For now just delete all the controller nodes below the camera, you don´t need them.
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
Hi michael,
thanks for the quick answer. Found it out in the same moment thankfully, but good to know that you are already working on it.
Cheers,
Klaus
