Vred - API - how to set animation frame?
Bob.Bon2000
Message 1 of 10
Bob.Bon2000
Hey
I need to set the animation frame to a specific one, how can this be done in vred python?
Thanks.
Replies (9)
Message 2 of 10
Christian_Garimberti
Hi, what do you mean?
are you playing a clip and want to set the play to a specific frame?
You can use playCAnimation(name, startFrame, endFrame)
Or something other?
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 3 of 10
Bob.Bon2000
Hello
Were building pipeline for vred and we want to ensure that vred always render specific frame for specific shots so that wrong data don't render.
Our project system manages render size/output/frame/etc/etc.
How can we do it via python?
Think of this
frame 0-10 wheels positions
Frame 10-100 accessory positions
Frame 100-500 etc etc
Our artist just say, render me wheel at x/y config, thus frame 4/7. etc
Thus need manual frame config via python.
Another reason for us to have it is that if artist is configuring shot, he would "preview" config XX and that would run setFrame(XX) + set bunch of other settings in scene so he can work from that. So its needed for both rendering creative work.
Message 4 of 10
Hi, with playCAnimation("myclip", 4, 4) (same start and end frame) you can preview a specific frame in the renderwindow
An then you can start the render to render that specific frame.
If you need to render more than one frame you can use
vrRenderSettings.setRenderStartFrame(4)
vrRenderSettings.setRenderStopFrame(7)
set the rendernimation with
vrRenderSettings.setRenderAnimation(True)
vrRenderSettings.setRenderAnimationClip("myclip")
setting also all the parameter yo need with the vrRenderSettings module
best
Chris
Message 5 of 10
Bob.Bon2000
Hello
Interesting thank you! Will check it out.
Will this also work under Design version of vred/node/core/etc?
I've seen some "This function only works in Pro" which causes some worries...
Thanks!
Message 6 of 10
Hi, palyCAnimation works on all platforms.
all the vrRendersettings too.
What does not works in the Design Version are the api to start the rendering, like startRenderToFile(alwaysOverride), where in fact, in the help, you find "This command is only available in VRED Professional"
Render node is a passive node so you cannot use it directly like the Pro, Design, Core.
Best
Chris
Message 7 of 10
Bob.Bon2000
Hey @Christian_Garimberti
I must be doing something wrong because nothing works that I try.
I'm in vred Pro 2023.2 atm.
Are these functions only limited to vred 2024+?
Running
playCAnimation("c", 40,40)
Does not move my slider anywhere on the frame time range, it's stuck where it is as is. I can't preview animation at specificx frame.
Any hints?
Message 8 of 10
hi @Bob.Bon2000 , i tried in Vred 2023.4 and it works.
For what i remember playCAnimation exists from time, so i suppose the 2023.2 should works the same.
Note then the Clip Maker panel and the timeline doesn't update... only the render window.
Best
Chris
Message 9 of 10
Bob.Bon2000
@Christian_Garimberti Will it change frame here >
 to specified frame in that command?
Just saw your video... we don't have clip, we have fbx with animation import.
Message 10 of 10
Hi, like written in the help. it should works on Clips and animation blocks.
Plays an animation block or animation clip from start to end via name. This function returns immediatly.
Parameters:
name (string) - name of the animation object
startFrame (float) - the optional start of the play range
endFrame (float) - the optional end of the pay range
Imported Fbx have only curves, so at least you have to create block, but i advice to put them also on a clip.
There is a video that shows how to do that.
https://youtu.be/3KWo1qYZfJw?si=4ItVWtPNhGh944oN
Best
Chris
