VRED 2024 - Python vrdTransformNode.setTranslation local mode
andreasK3K4G
andreasK3K4G
is there a way to set vrdTransformNode.setTranslation
with the option we have in the editor to use "local mode"?
So we can move along the groups orientation?
Christian_Garimberti
Hi, like written in the help. vrdTransformNode.setTranslation is in Local Mode.
Instead, vrdTransformNode.setWorldTranslation(translation)
Is for World Space
vrdTransformNode.setTranslation(translation)
Sets the translation in local space.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
andreasK3K4G
setTranslation is in local space.
But i mean the option to switch to local mode, like the option in the GUI Transform Button.
So when the group has an modified rotation pivot, that i can put setTranslation(10,0,0) and
the group get moved along the modified x-axis.
Sorry but maybe i didn't understand...
The "Local Mode" Switch is to manage the transform manipulator while working in render window.
It doesn't change the transformation of the object. i suppose only change the behavior the user interact while  graphically move objects.
Via Api you should use vrdTransformNode.setTranslation(translation) if you want to set a transform on a specific node, so it inherits transforms from the parent tree (it follow the parents transformation).
Instead, if you need to input a global transformation, no matter the parent tree, you should use vrdTransformNode.setWorldTranslation(translation)
otherwise... i didn't understand what you need...
Best
Chris
andreasK3K4G
Hi Christian,
thanks for the fast response. No worry, sometimes it is hard to describe.
The idea is to save me some line of code, cause i guess it is already inside of VRED.
Lets start from zero:
1. I have a line in VRED which present my direction vector. This line should be the new rotation axis.
2. My script is calculating the direction vector and set the rotation pivot orientation for the group the user wants to animate.
3. The user can now put in a value and choose the axis, and the group gets rotated around the new axis.
    The script can directly use anim_group.setRotationAsEuler(QVector3D(0,0,33))  (for example)
4. The user wants to move the group along the new axis, just typing in a value an choosing the axis.
5. Now it would be nice, to directly use anim_group.setTranslation(QVector3D(50,0,0)) (for example)
But for sure, it takes the local space and not along the custom axis.
I can write a function to get the new position with a given vector and a distance. I guess this is what happens anyway internal when the user use local mode in viewport. So it calculates the direction vector from the rotation pivot orientation values? and sets the new postion x,y,z with a proper math function.
So at the end it is just the question or as far i can imagine from your answers, more like a "nice to have", setRotationAsEuler takes the rotation pivot orientation into account, is setTranslation able to do aswell?
Maybe it is just me who needs this to save some line of code. 😉
sinje_thiedemann
Hi @andreasK3K4G
yes, in local mode the translation vector is essentially rotated. We can use the quaternion (QQuaternion) representation of the rotation and pivot rotation to get the rotated vector:
b = vrScenegraphService.getSelectedNode()
qr = b.getRotationAsQuaternion()
qro = b.getRotationOrientationAsQuaternion()
tr = (qr * qro).rotatedVector( QVector3D(100,0,0))
t = b.getTranslation()
b.setTranslation( tr + t) # or just tr
Using this, the object moves along its "local" x-axis, for example.
andreasK3K4G
Thank you, works perfect!
