VRED 2024.2 - Design vs. Professional, Full Product Comparison Chart
seiferp
Community Manager Community Manager
seiferp
Please find below our VRED 2024.2 Design vs. Professional Product Comparison Chart and check out our latest What´s New online documentation.
Data Import/Export & Preparation
VRED LE
VRED Design
VRED Professional
CAD Data Import Formats
Native support of more than 40 different CAD formats, WIRE, CatiaV5, NX, JT, IGS, STEP, IFC, 3MF...
Other 3D Import Formats
Alembic, C4D, 3DS, CSB, OSB, OBJ, DWF, VRML, *FBX, *PLMXML
FBX File Import Format
Support for Cameras, Joints, Skins, Keyframe & Vertex Animations, Lights, UV´s
PLMXML Import
Alias Interoperability
Cameras, Lights, Variants, Switch Materials, Template Geometry, Layer, Layer Folder, empty Layers, Alias Reference Assemblies
True NURBS
Shell and Components allow on demand re-tesselation of CAD data at any time
Smart References
CAD assembly monitoring and work with non-monolithic VRED files
Geometry Editor
Decore
Allows users to reduce 3D models to visually relevant information
Optimization Tools
Scene Graph Editor
Node Attribute Editor
Asset Manager
Example Asset Installer
Geometries, Materials, Environments, Sceneplates
Web Shops
Substance, Maground, Domeble, VRED Library
Multiple Render Windows
Customizable UI
Selection Modes
Select Components, Objects, Groups, Sceneplates, by Material, Adjacency, References, Parent, Hierarchy, Object Behind
UV Editor
Material UV- & Lightmap UV Set
Metadata Editor
Scene Tags
Advanced Data Import/Export & Preparation
 VRED LE
VRED Design
VRED Professional
File Export Formats
VPB & OSB, CSB, FBX, OBJ, WRL, 3MF, STL, JT, SLP
*VRED LE is limited to VPB & OSB export
A/B Side Handling
Toggle visibility of non-visualization relevant data without removing them
Lighting & Materials
VRED LE
VRED Design
VRED Professional
Delta Lights
Point, Spot, Directional
Area & Objects Lights
Disc, Rectangular & Spherical Lights
Light Textures
HDR & LDR Image Based Lighting
Skylight Environment
Real-time Shadows
Real-time shadow map support for Delta, Area & Object Lights
Real-time Shadow for Environments
HDR Light Studio Live Link
Area Light support with Tungsten Release or higher
VRED Material Types
Rounded Edges
Ratyracing only
Multi Pass Material
Layered Material
Switch Material
X-Ray Material
Subsurface Scattering
Substance - SBSAR Material
MaterialX
Nvidia - MDL
Light and Shadow Baking
Vertex- & Texture-based AO, Shadows & Light and Shadows on CPU & GPU (Cluster). *GPU only in VRED Professional
IES Light Profiles
  Advanced Lighting & Materials
VRED LE
VRED Design
VRED Professional
Volume Rendering
Homo- & heterogenous Scatter Volumes, VDB Volumes
* VRED Design read-only support
Rayfiles Visualization
Plain ASCII, Osram ASCII & ray file format, LucidShape ASCII, binary & spectral ray file format, Speos ASCII & ray file format (RAY_SPEOS10 & RAY_SPEOS20
X-Rite BTF Materials
X-Rite AxF Materials
Office Color Science - BRDF Materials
Camera & Effects
VRED LE
VRED Design
VRED Professional
Physical Lens Attributes
Camera Projection Modes
Perspective, Orthographic, Spherical Map, Peters Map, Vertical Cross, Horizontal Cross, Omnidirectional Stereo, Custom Matrix
Tone Mapping
Reinhard Luminance/RGB, Logarithmic Luminance/RGB, Filmic Tone Mapping, Physical Camera, Luminance & Illuminance
Depth of Field
Realtime- & Stillframe DoF
Motion Blur
Glow
Glare
Fog
Lens Flares
ACES Color Space
ACES Color Space for all RGB Tone Mappers
Vignette Effect
Camera Blend Maps
Camera Collision Detection
Camera / Backplate Matching
Rendering
VRED LE
VRED Design
VRED Professional
Display Clustering - OpenGL
H/W Rendering Modes
Realistic, Vertex/Face Normal, Baked AO, Indirect Illumination, Non- Photorealistic Rendering
Standard Pixel Filters
Triangle, Gaussian, B-spline
NVIDIA DLSS-RR (Deep Learning Super Sampling - Ray Reconstruction)
Requires GPU with NVIDIA Tensor Core technology
Variable Rate Shading
Desktop & Content adaptive, Foveated rendering support for HMD´s
Screen Space Ambient Occlusion
Transparency Modes
Object Sorting & Depth Peeling
Downscale
Downscales Raytracing render view resolution
Offline Render Passes
Color-, Material-, Illumination-, Image Processing-, Auxilary Channels
Variant Set Render
Configure and render combinations of Variant Sets within the Render Setting module
Render Queue
32 Bit Output
ICC Color Profiles
Advanced Rendering
VRED LE
VRED Design
VRED Professional
Display Cluster – Raytracing
H/W Rendering Modes
Analytic Rendering
Off-line Render Clustering
* Requires additional Render Nodes for VRED Design, VRED Pro can be clustered with other Pro´s
Real-time Raytracing Cluster
Cluster Manager
Real-time Render Passes
Render Layers
AI GPU & CPU Denoise Filter for Raytracing
NVIDIA OptiX AI-accelerated & Intel Open Image Denoiser
GPU Raytracing
Supported on NVIDIA GPUs with Maxwell or newer architecture
Advanced Pixel Filters
Box, Mitchell Netravalli, Lanczos, Catmull Rom, Sharp Triangle, Sharp Gaussian, Sharp B-Spline
Photon Mapping with Caustics
Spectral Rendering
Color Sprectrum using FWHM. Optis/Osram Spectrum file support
Photometric Rendering Parameters
Raytrace Material Overrides
Allows changing Raytrace Settings for Materials
Sequencer
Render Farm Support
Supports integration with render farm solutions, such as Deadline, Qube/pipeline FX, Smedge. Note, requires custom integration
Histogram
Shows Histogram in Viewport for R, G, B, Logarithmic Scale & Grayscale
Image Meta Data
Saves Render Settings, Cameras, Scenegraph visibility and Material Switch state in Image Meta Data
Storytelling
VRED LE
VRED Design
VRED Professional
Sceneplates
2D Backplates (Images, Image Sequences) & 2D Frontplates (Text, Images, Image Sequences, HTML5* read only in VRED Design)
3D Environments
Variants & Variant Sets
Camera Viewpoints
Curve Animations
Clip Maker with Animation Wizard
Advanced Storytelling
VRED LE
VRED Design
VRED Professional
Advanced Animation Capabilities
ClipMaker Add Sequence, VRML Animation Editor
Additional Scenegraph Nodes
Material Group, ClipPlane, Billboard, Matrix Transform, Sound & Sound Obstructer, Distance LOD, Stereo Switch, Host Switch
Evaluation
VRED LE
VRED Design
VRED Professional
Grid & Ruler
Standard Measurements
Point/Point, Point/Object, Object/Object, Line/Object & Circle Measurement
Clipping
  Advanced Evaluation
VRED LE
VRED Design
VRED Professional
Direct NURBS Rendering
Gap Analysis
Surface Analysis
Analytic rendering modes for high end surface evaluation, Alias Curvature Mode on nurbs data
3D Annotations
Advanced Measurements
Gap Measurement
Presentation & Communication
VRED LE
VRED Design
VRED Professional
HDR10 Display Support
OpenVR & OpenXR* Support
* Not supported yet: Full Python support, Eye Tracking & Foveated Rendering, Windows MR, Varjo Quad viewport & Depth estimation
Oculus Rift & Rift S, HTC VIVE, VIVE Pro, VIVE Pro 2, VIVE Pro Eye, VIVE Cosmos & VIVE Cosmos Elite, WinMR, HP Reverb, HP Reverb G2, VRHero/XTAL, StarVR , Varjo VR-1, VR-2, XR-1, XR-3, Aero HMD & Logitech VR Ink Pilot Support
WinMR Headsets and HP Reverb HMD are supported via OpenVR
VR/Desktop Multi- User Collaboration
Avatar & Controller representation, OOTB Teleport, Laser pointer, VR menu & 3D spatial speech & audio support
Stereo SLI
3D Mouse & Joystick Support
Touch Sensors
Standard Stereo Modes
Active (Double Buffer), Horizontal- & Vertical Interlaced, Left/Right & Top/Bottom Split, Separate Left- & Right Eye
Remote Session Connection
Publish Project / Package
Save a package containing all referenced data and content. Encryption & Timestamp support
Shared Views
Advanced Presentation & Communication
VRED LE
VRED Design
VRED Professional
VRED Go
Publish Windows Executables
VR Hand Interaction
* limited interaction in VRED Design if scene was not prepared in VRED Pro before
HTML5 Media Editor
Anaglyphic Stereo Modes
Red/Cyan, Blue/Yellow, Green/Magenta
VRPN Motion Tracking
VRED Presenter
Included in the VRED Pro installation package
VRED App
Web/Mobile presentation controller
VRED Stream App
Web interface to navigate variant sets, viewpoints, quality settings & create/join collaboration sessions
VRED Stream
JPEG, PNG (with Alpha Channel)  & H264 (H264 codec must be installed)
Scripting
VRED LE
VRED Design
VRED Professional
External Web Interface
Web API
Python v2 API access via JavaScript
Advanced Scripting
VRED LE
VRED Design
VRED Professional
Python 3 Scripting API with Editor
* Script execution only in VRED Design
Script Plugins
Add plugins & modules to main menu bar
Command Line Terminal
ADP
VRED LE
VRED Design
VRED Professional
Opt-in/Opt-out options
By participating in the program, you add valuable input that helps us to decide how to improve the overall customer experience with Autodesk software
Thanks for sharing this informative content.
