VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Vive tracker buttons
5 REPLIES 5
651 Views, 5 Replies
Is there any way to detect when the vive tracker button has been pressed? I would like to implement some functionality based on that button press.
5 REPLIES 5
what exactly is the button you call the "vive tracker button" There is a way to track all the buttons and retrieve the parameters.
Tell me which button exactly we are talking about and I will help you
Have a good day
This button. If you can also use the pogo pins on the back of the tracker that would good also.
I do not have this device at my fingertips, so I could not provide a solution all in hand.
However, the Vred API provides a function
GenericTracker0 = vrOpenVRController ("GenericTracker0")
GenericTracker0.connectSignal ("buttonPressed", MyPressedFunction)
The two HTC controllers are controller0 for the right and controller1 for the left. And GenericTracker0 GenericTracker1 etc ... for trackers
def MyPressedFunction (Id):
     print (Id)
And this function gives the id of the button pressed. This allows you to filter and above all to assign relative functions.
I hope helped you. Regards,
Good day
marc.winter2
can't get this to run. Is this the current best practice solution?
Best regards Marc
luqiang.han
in reply to: marc.winter2
The buttons you want to use should be on the Tracker? If not, I have a better idea.
Just use a laser pointer. You could buy a laser pointer, which has at least two buttons.
You could do a lot of things with it in VRED.
