Hello everyone, I have a little problem :
I'm currently working on Vred 2024.1, and I try to make my Varjo VR-3 tracked by ART, I have setup a VRPN server which receive the ART data from DTRack3, and I have installed the LPVR-CAD plugin to made the HMD tracking in Varjo Base, but whatever I try, my Varjo VR-3 isn't tracked in VRed, and I can't understand why, if someone has an idea !
Thanks in advance,
Adrien PEYRARD
You do not need to setup VRPN in VRED, only varjobase should be ok. Actually, if you both use port 5000 in vrpn and Varjobase, there maybe a problem. Please open a webpage with the address: localhost:7119 to check if your lpvr works normally.
I'm working with Adrien on this and I opened the browser with localhost:7119. The problem is that there is no data coming. In our setup we have 2 networks and the link is done by Dtrack3 app with act as router. I made sure UDP protocol is allowed but still not working.
