Use ReactJs pages inside HMI display
I need to use some pages/apps built with ReactJs to simulate HMI interactions inside VRED.
I tried to deploy the page with the straighfoward approach but the program displayed nothing but a blank screen.
Is it possible to use React and other advaced JS resources in VRED 2019? Is there something i must setup? My company already have plenty of ReactJS based HMI's and we really need to include it on our simmulations.
Best regards.
seiferp
it´s not trivial but possible to get your ReactJS applications running in VRED. It´s actualy more a web dev. task and not VRED related at all. Here is a short guide were I´m using the calculator example that can be downloaded from GitHub
  • Install NodeJS
  • Unzip the GitHub project on your desktop
  • Open your command-window and type node -v to check if Node.js was installed successfully
  • Navigate in the command-window to the calculator-master example folder on your desktop and type npm install to download all required files for your react project
  • When the download is finished you can see multiple files got added to your example folder!
Start React server
  • Type npm start in your command-window
  • You can now use http://localhost:3000/ as URL in the VRED MediaEditor while your React App is running in the background
Transcript HTML
  • Terminate your running job in case the React App is still running
  • Type npm run-script build
  • This has created an addition folder called build in your calculater-master example folder with an index.html you can load in the Media Editor
  • Note: As the console-output states it´s assuming it is hosted on a server at /calculator/ and the index.html is searching for it´s files at the wrong location!
  • Therefore you have to remove all /calculator/ andin front of static from the src=paths in the html file
Hope this helps
Pascal
seiferp
It´s pretty much straight forward once you get the idea behind ReactJS. If your company is building HMI´s with ReactJS you must have some experts onsite and I wonder if no one else in your company could help you with getting the server started or transcripting the ReactJS apps into HTML 🤔
Thank you for the answer,
I'll try this approach!
Sorry for the late response,
The problem was solved with this approach!
Thank you.
seiferp
Glad to hear 👍
