Unable to Set View - Display - OpenVR HMD
Witzbold1992
Witzbold1992
Hello everyone,
I just loaded the VRED 2019 Pro Demo to try out the HTC VIVE Features. I followed the Steps in this (https://knowledge.autodesk.com/support/vred-products/learn-explore/caas/simplecontent/content/adding...) tutorial. The Program crashes when I choose View / Display / OpenVR HMD.
Any Solutions?
michael_nikelsky
Does OpenVR work in the default scene or with one of the test scenes we ship? If not you probably need to update SteamVR. You need at least the version from january of this year, older steam VR versions will no longer work.
Kind regards
Michael
Michael Nikelsky
Sr. Principal Engineer
Witzbold1992
Thanks for the quick reply.
It also crashes in the default szene.  We installed SteamVR today for the first time on this computer and downloaded and installed it fresh, so it should be the newest version. I think we also checked for updates because we thought about a Problem with OpenVR, but I'm not sure - I will double check this.
michael_nikelsky
What GPU and driver version are you running?
Michael Nikelsky
Witzbold1992
Sorry for the late reply. After we updated the GPU Driver it worked fine, thanks!
