Syncronizing variants from script not working
Dear VRED community,
i am working on a scene with two workstations connected through the connector. everything is fine, except that variants only get synced if i doubleclick them in the GUI. if i run the command "selectVariantSet("XXX", false)", only the variant set on the machine running this script gets activated.
is there a possibility to select variant sets from script and get them synchronized?
thanks and best regards,
S.
sinje_thiedemann
which version are you using?
There was a bug that caused exactly the issue that you describe.
It was fixed in 2017 SP2 and 2017 SR1.
Best regards
Sinje
hi,
i was using 2017 SR1. I'll test it with 2018 and will tell you if it works or not. Thanks for the help!
BR
As far as I know, this doesn't work. Even in 2018. Several scene changes you do via script will not be synchronized by the connector.
sinje_thiedemann
I just found out that the python command needs to be passed to executePython (see vrScript in Python doc). It is then transferred to connected VREDs.
For example:
executePython('selectVariantSet("Set1")')
Does this work for you? (You still need to use at least version 2017 SR1 or 2017 SP2.)
Best regards
Sinje
Yes, here it works with VRED 2017.2
Thank you.
