VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Sharp Shadow
2 REPLIES 2
2110 Views, 2 Replies
Sharp Shadow
Hello everyone. I'm rendering a 3D car scene using a HDR and (DirectionalLight) to catch sun shadow with the shadow plane but for some reason under the car my shadow is too sharp as the image.
Vred Pro 2015 SR1-SP3.
Thanks! 😉
2 REPLIES 2
seiferp
Hi buletvfx,
to me it looks like that there is a sun in your hdr already but probalbly not bright enough to cause shadow. You are using the directional light to get this effect on the ground plane. Am I´m right?
Right click on your environment in the material editor and select "Boost Light..." Play with the Boost and Treshold values to adjust the HDR to your needs.
Otherwise you should use one of the area lights ( Sphere, Disc or Rectangular) in Raytracing. Scale it to your needs and place it at the position the sun comes from.
Directional, Point and Spotlight are not really working correctly in Raytracing because they refer to one single point which is not existing in the real world. Lightsources like a sun, a bulb or a led light are always (more or less) self illuminating surfaces or objects.
Cheers
Pascal
in reply to: seiferp
Hello Seiferp!
Well, I did exactly what you said using a Spotlight in the light editor with the Area light enable and It's working like it should. Now my shadow is nicely soft and I'm pretty happy with the results.
Thank you so much for the help 😉
