render node licenses
cikho
cikho
hello all.
quick question:
i remember that in older versions of vred pro, some render-node licenses were included.
i wonder if this is still applicable, given that render node as been replaced by vred core.
we have recently added 2 vred pro licenses to our rooster, having now 2 pro and 5 design.
i was wondering if we can add the design-driven PCs to a potential cluster using the pros.
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
Christian_Garimberti
Hi, CPU or GPU cluster?
for gpu cluster you can only use Vred Pro (up to 2 gpu per license) or Vred Core (1 gpu per license)
For cpu you can use Vred pro or render nodes license.
Vred design cannot be used as render node, I think it can only be used as master in a cluster of render nodes.
Note, for clustering you can only use multi user (net) license, no single user license.
https://forums.autodesk.com/t5/vred-forum/cluster-issue/m-p/9280356
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
