Python script to auto adjust environment settings
dutchy4c
dutchy4c
I’ve been trying to write a python script to auto adjust the environment settings but I keep on running into issues where VRED Python is not allowed access to environment settings to adjust, even though they’re clearly there and adjustable. Is there a block on these out does anyone know a work around?
 Thank you!
 Cor
michael_nikelsky
There is no block, everything that is accessible via the vrdSphereEnvironmentMaterial or vrdSkylightMaterial should be adjustable. You should no try to use the old Fieldaccess directly, there are a lot of fields that are for internal use only or are not used at all.
What are you trying to adjust?
Michael Nikelsky
Sr. Principal Engineer
dutchy4c
Thank you.
I want to put a color chart in a scene, with set color values, and then have a script run that would automatically set the right environment values to bring out the true colors.
