Python command for toggle Collaboration Window
Shawn_Collins-Lopez
Shawn_Collins-Lopez
I cannot find the Python command to toggle on and off the Collaboration window in the VRED Pro interface.
Attached screen grab of the window in question.
Need to create a Hotkey and Auto Load for it...
Thank you, Shawn
dlincol1
Hi Shawn,
The vrMenu class should have the methods you are looking for.
https://help.autodesk.com/view/VREDPRODUCTS/2022/ENU/?guid=VRED_Python_Documentation_Python_API_V1_v...
In the example filemenu3d_scene.py I modified line 11 as shown below to display collaboration menu.
menu.setWindowResize("Collaboration", 640, 400)
Dan
Shawn_Collins-Lopez
Hi Dan,
Thank you for pointing me to the demo script.  Its cool to map a VRED menu to a cube but that's not what I am looking to do.
I just want to toggle on and off the Collaboration window in VRED without mouse clicking the icon or going to Interaction - Collaboration.  Too many clicks to get to the window.
I'm looking to make a toggle like the preferences scripts:
keyQs = vrKey(Key_Q, ShiftButton)
keyQs.connect("togglePivotManipulator()")
keyQs.setDescription("Toogle Pivot Manipulator")
The Collaboration window will auto open when I use the VRED-Collaboration.vrs attachment.  When you double click it will auto load VRED and open the Collaboration window and fill out the address.
This is the code in this .vrs file:
<?xml version="1.0"?>
<vred_collaboration link="USBLXWDCAD929DK/6a1b61612bc4e3" version="1"/>
Just want a toggle hotkey to open the window!
Thank you for your assistance.
Shawn
sinje_thiedemann
The function to open the GUI of a module is showModule(...), in this case
showModule("Collaboration")
Another idea would be to save a Window Layout with this module opened?
Or add collaboration module icon to the bottom icon bar (by drag&drop).
Shawn_Collins-Lopez
Thank you this code works!  Where in the documentation would I have found this?
In addition I can use hideModule("Collaboration") to turn it off too.  Just what I was looking for!
Thank you!
