Play pause animation with a single variant (Setting a single hotkey) usign python
fabiodimperio
Message 1 of 22
fabiodimperio
Hi everybody!
I tried the script in "Script Editor":
isPlaying = False
isPausing = False
def myPlayToggle():
global isPlaying
global isPausing
if not isPlaying:
playCAnimation("Insieme")
isPlaying = True
else:
isPausing = not isPausing
pauseCAnimation("Insieme", isPausing)
Once I do double click on the Variant is not running.
And the promp write the message:
File "<string>", line 1, in <module>
NameError: name 'myPlayToggle' is not defined
Can someone help me?
I attach the sample file.
Thank you
Replies (21)
Message 2 of 22
__daniel.lincoln__
Hi, it looks like your script lost the original indentations from the example.
Just add the indentations back and it seems to work.
isPlaying = False
isPausing = False
def myPlayToggle():
    global isPlaying
    global isPausing
    if not isPlaying:
        playCAnimation("insieme")
        isPlaying = True
    else:
        pauseCAnimation("insieme", isPausing)
Message 3 of 22
fabiodimperio
I don't know if I am doing something wrong.. But it is not working yet
Message 4 of 22
__daniel.lincoln__
Did you press the 'Run' button in the Script Editor after adding the indentations?
Message 5 of 22
fabiodimperio
Yes. But nothing happens
Message 6 of 22
__daniel.lincoln__
Message 7 of 22
fabiodimperio
Maybe is the vred version. I am using 2022.2. Do you think should be this? I tried to restart vred. Sometimes work. most of the times doesn't. 😞
Message 8 of 22
__daniel.lincoln__
It is working for me in 2022.2. Are you clicking in the render window to give it focus and then pressing the Hotkey?
Message 9 of 22
Christian_Garimberti
Hi Fabio, do you still have error, red lines, in the terminal after pushing the Run button on the script editor or after executing the variatset?
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 10 of 22
fabiodimperio
Yes I do. But nothing changes
Message 11 of 22
fabiodimperio
@Christian_Garimberti No errors yet. But doesn't work
Message 12 of 22
fabiodimperio
Message 13 of 22
fabiodimperio
Video Sample
Message 14 of 22
Could you share again your vpb file so we can test on it?
Best
Chris
Message 15 of 22
fabiodimperio
sure!
Message 16 of 22
You have to put somewhere a resetCAnimation('ClipName').
If not, when the animation is ended, it plays no more.
To be sure all your animation are ready after loading the file, put it on the script editor.
If you want to reset while using, create a variantset
Best
Chris
Message 17 of 22
fabiodimperio
Thank you Chris! 😄 Now it works! One last question. I tried a variant set to stop the animation. It could be useful for me.
As you can see in the video, when I press play and pause it works properly, but if I try to stop the animation (reset), play doesn't work. I have to run again the script.
Is there a way to avoid running again the script after stopping the animation?
Message 18 of 22
fabiodimperio
Message 19 of 22
Stop does not exists, the pause is the same thing and it is enough.
probably, when you execute the reset, you have to reset also your variables isPlaying and isPausing accordingly.
So when you write
add also
isPlaying = False
isPausing = False
Best
Chris
Message 20 of 22
fabiodimperio
You mean in the var set or in the script editor?
