Hi i want to start, stop and resume a animationclip with a key or touchsensor.
I found this Thread about it https://forums.autodesk.com/t5/vred-forum/vred-play-pause-animation-with-a-key/m-p/6045355
But it seems not working in Vred Pro 18.4.
Any ideas?
regards chris
Solved by marcus_fritzen. Go to Solution.
attached is a simple demo scene with the desired behavior. It consists of a cube with an animation block, as well as three variant sets for play (Key A), pause (Key S) and resume (Key D). The variant sets again execute script code for the animation. Same principle should also work for animation clips. The scene was created and tested with 2018.4.
Cheers,
Marcus
Update: still works in 2019.3. It just doesn't like to go from pause back to play. If it gets "stuck", hit resume, then play.
