Open a vpb file from a script
leonardo.k
leonardo.k
Hey guys, need a little help here.
I have a lot os files sometimes to open, and I wonder if is possible to make a VSET with some script that I can open this files.
I try with getOpen but this way Vred open the File>Open Menu, and I need to open the vpb files direct from script.
Can anyone help me on that?
__daniel.lincoln__
vrFileIOService.loadFile('C:/ProgramData/Autodesk/VREDPro-16.0/examples/Automotive_Genesis.vpb')
leonardo.k
Nice!! many thanks!!!!!
leonardo.k
This works, but the file is open inside the one that I already using, there is a way to close the open file and then open the next one?
__daniel.lincoln__
This should do what you asked, but it sounds like you may need to setup some type of batch process.
import subprocess
subprocess.Popen(["C:/Program Files/Autodesk/VREDPro-16.0/bin/WIN64/VREDPro.exe", "C:/ProgramData/Autodesk/VREDPro-16.0/examples/Automotive_Genesis.vpb"])
terminateVred()
There are some batch processing examples here:
https://help.autodesk.com/view/VREDPRODUCTS/2024/ENU/?guid=VRED_Tutorials_VREDCore_Tutorials
Dan
Christian_Garimberti
You can try using a vrFileIOService.newScene() before to load your file.
or using the V1 Api
vrFileIO.load(filename, filenames, parent, newFile, showImportOptions)
with newfile True should call a newScene() before to load
best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
