Mtlx authoring in VRED. Open Source Plugin now available.
scottXWLZ5
Message 1 of 23
scottXWLZ5
Hi All,
Thought I would make a post on here to share my open source plugin release. This now allows full mtlx authoring inside VRED via a node graph window.
Numerous examples and presets, preview shader once the material has been pushed to VRED. A handy validator for the material which can spot errors before and show diagnosis before sending. It uses each unique VRED versions mtlx library that it ships with. In theory this means versions 2024-2026 should work (I developed and tested this on 2027 version) but I cannot account for the python syntax changes between versions if there is a discrepancy.
Please use this post, my Linkedin or Github itself to share issues found, requests or anything else you can think of. I'd like to support this as much as I can until Autodesk release a true native one.
https://github.com/ScottRaffertyCG/VREDx
Cheers!
Scott
Pyre Labs founder
Replies (22)
Message 21 of 23
clemens_schlicker_audi
It's really not a priority since your approach also just works, but it might be interesting for you to toy around with that approach.
I use Inno Setup to compile my file/folder structures to my internal "customers". There you can specify the hidden attribute.
At the end, you could also ship a convenient setup.exe that installs to a user-defined directory (with reasonable default suggestion) rather than providing a zip file with instructions as a release.
Message 22 of 23
scottXWLZ5
Very interesting. I will take a look at that!
Message 23 of 23
mnosbues
Hi Scott,
great work – impressive. When testing the plug-in (with 2027.1-beta) I noticed the following bugs
Bugs
Nodes cannot be renamed
For a Nodegraph node the positions are ignored when they exist in a loaded MTLX
Nodegraph node positions are not stored in a saved MTLX
when using the +/- icon in the editor on a node to expand and compress a node the node connections are not updated to the new anchor positions
Cheers,
Martin
