memory error VRED 2026
wanderson_rochaX6XNY
Community Visitor
Community Visitor
Hello, i'm having the following error while using my Vred:
"An Application has requested more GPU memory than is available in the system.
The Application will now be closed.
Error code: 6"
i've read that the 2022 version have a option named "Clear GPU Memory" for this kind of error, but i couldn't find it in the 2026 version
my specs:
I7 12th Gen
16GB DDR5 4800Mhz
NVIDIA T1000
CamAdicionar
Can someone help me ?
seiferp
The Clear GPU Memory can be found in the Preferences > Rendering > Render Window > Advanced Rendering Tab
Quick Tip: You can simply type in the search bar at the bottom of the Preferences dialog and it will guide you there 😉
