I got stuck with the Problem that all my Materials got the same Material ID.
When exporting the MaterialID Renderpass i will only get one Red Mask.
Thanks for your help in advance!
Sebastian
Solved by richardlevene. Go to Solution.
You have to change the material ID value in the material for the object.
Go to the material editor, click on the material and scroll down to the Raytracing Section and you will see the Material ID colour.
If you have the same material on multiple objects then they will all be the same ID colour. If would want them to have the same material but different ID colours then you will need to create duplicates of the material and change the material ID value for each material and assign as needed.
Richard
