Issue in Clip using viewpoints and rendering only a range of frame
Hi guys,
i found a small issue working on a clip with some viewpoints.
I used viewpoints to manage camera position in the animation and all is working ok if i render the clip starting from the 0 frame.
But if i render only a range of frames, the viewpoint activated is the first AFTER the start frame i set and not the last BEFORE it.
In the example i made, i got 4 viewpoints, each one facing a colored box face. The first is the red viewpoint, at the frame 0. Then i have the Green one at frame 24 and then the others.
Rendering from the frame 12, the first image rendered is already with the green viewpoint. I assume that at the frame 12 the red one should still be active.
I attached the scene to test.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
