Hi
I got a brand new machine running 2 Quadro P6000 under W07
I'm using VREDPro version 2018.4 .
I'm using adaptator HDMI --> DisplayPort for the connection from the HMD to one of the Quadro P600 (only display port are available on such kind of graphic card)
Vred can't have access to steamVR (see snaphot) when I'm turning view display as "Open VR HMD"
I have perform several tests with SLI mode or 2 separate Quadro mode , result is the same ...
I have read somewhere that the HMD should be plug on the same graphic card than the main display and it's the case here .
Do you have any idea to help me in this graphic conf ?
