How to set Tessellation Quality with JT - Legacy Loader - Tessellate all Breps
Message 1 of 1
Hi!
I need to use the JT - Legacy Loader because the Autodesk loader does not import the JT Material names.
For example Instead of "OG00000002" I get "surface_style (0.596078, 0.666667, 0.686275".
I'm fine with using the Legacy Loader except to one issue.
I don't find the option to change the Tessellation quality.
Changing the Tessellation Quality in the JT Settings has no effect.
I might be wrong with this but it seems to me that the Legacy Loader just takes the highest mesh LOD available.
Keep Surface Data doesn't seem to work as well, because i'm not able to use the Geometry Editor later on.
Background Infos (Also see pictures attached):
In the documentation (https://knowledge.autodesk.com/support/vred-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...) it says:
  • "Use Legacy JT Loader - Bypass the Autodesk loader settings of VRED and instead use the legacy JT file sharing protocol." So that means to me the other settings will have no effect.
  • "Breps Handling - Manage objects with exact boundary representation surfaces. Use the options to load and tessellate all Breps, or load the Breps of your choosing without tessellating." The only option which gives me useful results is "Tessellate All Breps"
Legacy VS Autodesk loader .pngLoadJT Breps.jpgLoadXT Breps.jpgTessellate All Breps.png
Replies (0)
