is there a list of all the VRed hotkeys ?!
Solved by seiferp. Go to Solution.
Hi robb,
View > Show Shortcuts
Animation Channels -----
Ctrl + Shift + V Paste Clone Block
Ctrl + V Paste Block
Animation ClipMaker -----
Ctrl + A Select All
Ctrl + C Copy Clip/Block
Ctrl + D Duplicate Clip or Clone Block
Ctrl + I Show Clip/Block Information
Ctrl + R Rename Clip/Block
Ctrl + V Paste Clip/Block
Del Delete Clip or Block
F Frame Clip
Animation CurveEditor -----
Ctrl + A Select All Control Points
Ctrl + C Copy Control Points
Ctrl + K Key All Channels
Ctrl + Shift + K Create Block
Ctrl + V Paste Control Points
Del Delete Control Points
F Frame Curves
X Move/Zoom Only in X-Direction
Y Move/Zoom Only in Y-Direction
Animation Library -----
Ctrl + A Select All
Ctrl + C Copy Block
Ctrl + D Duplicate Block
Ctrl + I Show Block Information
Ctrl + N Select Node in Scenegraph
Ctrl + R Rename Block
Ctrl + Shift + A Deselect All
Ctrl + Shift + D Clone Block
Ctrl + Shift + G Group Selected Nodes
Ctrl + X Cut Block
Del Delete Block
Camera Editor -----
Ctrl + D Duplicate Camera or Viewpoint
Ctrl + R Rename Camera or Viewpoint
Del Delete Camera or Viewpoint
GLInfo -----
Ctrl + C Copy Currently Selected GL Extension String to Clipboard
HDR Light Studio Plugin -----
L Toggle Light Paint Tool
Interaction -----
Alt + Left Mouse Button Fix Face Normal
Alt + Middle Mouse Button Fix Surface Face Normal
Alt + Right Mouse Button Fix Connected Face Normal
Ctrl + Left Mouse Button Navigation Pan
Ctrl + Right Mouse Button Navigation Center
Ctrl + Shift + Left Mouse Button Select Object (Add)
Ctrl + Shift + Right Mouse Button Deselect Object (Sub)
Down Move Camera Backward
Left Revolve Camera Left around Pivot
Left Mouse Button Navigation Rotate
Left Mouse Button + M Material Copy
Left Mouse Button Double Click Camera Set Pivot
Middle Mouse Button Double Click Camera Zoom to hit point, Set Pivot and Look At
Right Revolve Camera Right around Pivot
Right Mouse Button Navigation Zoom
Right Mouse Button + M Material Apply
Right Mouse Button Double Click Camera Set Pivot and Look At
Up Move Camera Forward
Light Editor -----
Ctrl + A Select All Lights
Ctrl + D Duplicate Light
Ctrl + F Find Light
Ctrl + G Create Group
Ctrl + I Invert Selection
Ctrl + N Select Scenegraph Nodes
Ctrl + R Rename Light
Ctrl + Shift + A Deselect All Lights
Ctrl + Shift + G Create Group from selection
Ctrl + T Toggle Light Enabled State
Del Delete Lights
MainWindow -----
Ctrl + Alt + S Save Selected
Ctrl + E Open Stereo Settings
Ctrl + O Open File
Ctrl + S Save File
Ctrl + Shift + O Add File
Ctrl + Shift + S Save File As
Material Editor -----
Ctrl + A Select All Materials
Ctrl + C Copy Material
Ctrl + D Duplicate Material
Ctrl + M Apply Material to Selected Nodes
Ctrl + N Select Nodes
Ctrl + R Rename Material or Tag
Ctrl + Shift + A Deselect All Materials
Ctrl + Shift + G Create Group from Selection
Ctrl + Shift + N Add Nodes to Selection
Ctrl + Shift + V Paste Clone Material Chunk
Ctrl + U Remove Unused Materials
Ctrl + V Paste Material
Del Delete Material or Tag
Esc Deactivate Texture Manipulator
F5 Update Material List
T Toggle Texturing Mode
Measurement -----
Del Delete Selected Measurement
Render Layer -----
Ctrl + A Select All
Ctrl + D Duplicate Layer
Ctrl + Down Move Item Down
Ctrl + R Rename Layer
Ctrl + Up Move Item Up
Del Delete
Render Queue -----
Ctrl + A Select All RenderJobs and Actions
Ctrl + R Rename
Ctrl + T Toggle RenderJob or Action Active State
Del Delete RenderJob(s) / Action(s)
Render Window -----
Alt + Return Toggle Fullscreen Mode
Ctrl + Alt + Return Toggle Multi Display Fullscreen Mode
Ctrl + F12 Recache
Ctrl + F9 Swap Face Normals
Ctrl + L Align Camera Tool
Ctrl + P Create Snapshot
Ctrl + Return Toggle Dock Mode
Ctrl + Shift + T Unsplit Selected Group of Triangles into a Geometry
Ctrl + Space Show Overlay to Switch Active Camera
Ctrl + T Split Selected Geometry into Triangles
Ctrl + W Toggle Realtime Antialiasing
Ctrl + Y Redo
Ctrl + Z Undo
End Toggle Rendering
Esc Leave Fullscreen Mode
F Zoom to Selected Object
F10 Headlight
F11 Wireframe
F12 Statistic
F2 Render Mode Analytic High
F3 Render Mode Realistic High
F4 Render Mode Raytracing
F5 Render Mode Face Normal
F6 Render Mode Surface Analysis
F7 Render Mode Ambient Occlusion
F9 Swap Normals
Home Set Field of View
I Isolate View Selected
K Animation Key All
Left Mouse Button + R Region Selection
Q Adapt Zero Parallax Distance
R Activate/Deactivate Region Rendering
R Activate Region Selection in Region Rendering Mode
Shift + E Activate Rotation Manipulator
Shift + F Show All
Shift + F10 Double Sided Lighting
Shift + F12 Flymode
Shift + F9 Swap Vertex Normals
Shift + K Animation Key Selected
Shift + Q Toogle Pivot Manipulator
Shift + R Activate Scale Manipulator
Shift + W Activate Translation Manipulator
Space Toggle still frame antialiasing
Scenegraph -----
< Shrink Component Selection
> Grow Component Selection
Ctrl + A Select All
Ctrl + Alt + D Duplicate Node to Cloned Tree
Ctrl + B Set to B Side
Ctrl + C Copy Node
Ctrl + D Duplicate Node
Ctrl + Down Scenegraph Selected Node Navigation Down
Ctrl + F Find Node
Ctrl + H Hide Node
Ctrl + J Show Node
Ctrl + Left Scenegraph Selected Node Navigation Left
Ctrl + R Rename Node
Ctrl + Right Scenegraph Selected Node Navigation Right
Ctrl + Shift + B Set to A Side
Ctrl + Shift + D Clone Node
Ctrl + Shift + F Scroll to Selected Node
Ctrl + Shift + G Group Selected Nodes under a New Group Node
Ctrl + Shift + H Hide All Nodes
Ctrl + Shift + I Invert Selection in Group
Ctrl + Shift + J Show All Nodes
Ctrl + Shift + M Merge Geometries
Ctrl + Shift + T Unsplit Geometries from Triangles
Ctrl + Shift + V Paste Clone Node
Ctrl + T Split Geometry in Triangles
Ctrl + Up Scenegraph Selected Node Navigation Up
Ctrl + V Paste Node
Ctrl + X Cut Node
Del Delete Node
F Zoom To
Script Editor -----
Ctrl + F Open Find Dialog
Ctrl + R Open Replace Dialog
Sequencer -----
Ctrl + A Select All Sequences and Actions
Ctrl + D Duplicate Sequence / Action
Ctrl + R Rename
Ctrl + T Toggle Sequence or Action Active State
Del Delete Sequence(s) / Action(s)
Variant Sets -----
Ctrl + D Variant Sets List: Duplicate VariantSet
Ctrl + G Variant Sets List: Create Group
Ctrl + R Variant Sets List: Rename VariantSet
Del Variant Sets List: Delete VariantSet
Return Variant Sets List: Activate VariantSet
Variants -----
Ctrl + D State List: Set Default State
Ctrl + N Geometry Variant: Select Nodes
Ctrl + R Variants List: Rename Variant
Ctrl + R State List: Refresh States
Del Variants List: Delete Variant
Return State List: Activate Selected State
Cheers
Pascal
